[Qgis-user] QGIS 2.2 - Remove layer dialog
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Feb 26 03:22:25 PST 2014
> I didn't want to throw away all that was done, I'm sorry if it sounded
> like that. I reopened the ticket because a few people (including me)
> disagreed with the change, and did not take part in the initial discussion.
Like Etienne, I completely missed the original discussion, and similarly
quite strongly about it.
> I understand too many options are not a good thing, on the other hand
> choice is good when it's not too confusing and easy to implement.
I agree there can be too many options, but also too few. This seems like
something that warrants a config option; consider - the recycle bin in
Windows has similar options - confirm to delete etc.
Jürgen:
> But IMHO that rather small issue got much more attention (and did and
> still does cause much more distraction) than it deserves.
I think that's probably because it's something people feel very strongly
about. I believe that's a clear indicator that an option is probably be
warranted otherwise this issue will keep coming up.
Also, no-one has commented on the fact that delete and Backspace don't seem
to work for me in 2.2. Do they work for others?
Just my thupence. :-)
Cheers,
Jonathan
> On Tue, Feb 25, 2014 at 5:57 PM, Richard Duivenvoorde <rdmailings at duif.net
> > wrote:
>> Hi Etienne,
>> I'm fine with the solution of Jef: make it an option (now that it is
>> done).
>> But in general: I do not like the fact that we had, I think, a
>> discussion of about 2 weeks with several people, which is thrown out of
>> the window because one reopens an issue and makes some noise. Apparently
>> the time we/I put into this discussion was not worth my time.
>> Besides this: I do not think having an option for everything is the best
>> option ;-)
>> Better to have a sensible default, have a discussion/voting and then
>> deal with that. An extra setting I see as a bad compromise here. The
>> Settings dialogs are getting more and more crowded with options I do
>> really not know anymore for which minimal detail it is giving me options
>> for.
>> Please let us create some (ui/hud) vision and hold on to that, so we are
>> not driving on user comments only.
>> Regards,
>> On 25-02-14 18:24, Etienne Tourigny wrote:
>> > I find it rather annoying also, and re-opened the bug.
>> > On Tue, Feb 25, 2014 at 2:11 PM, Jonathan Moules
>> > <jonathanmoules at warwickshire.gov.uk
>> > <mailto:jonathanmoules at warwickshire.gov.uk>> wrote:
>> > Hi Jürgen,
>> > Thanks for the link.
>> > From attempting to read that:
>> > - There's no way to turn it off. :-(
>> > - Shortcuts must be used instead. :-(
>> > - Delete or Backspace should delete a layer without asking for
>> > confirmation.
>> > Is this correct?
>> > Because if so, neither Delete nor Backspace works - they don't do
>> > anything at all. Am I doing something wrong?
>> > (Ctrl-D works - but that brings up the dialog... :-S )
>> > Did I miss something or is this a bug?
>> > Best,
>> > Jonathan
>> > On 25 February 2014 16:34, Jürgen E. <jef at norbit.de
>> > <mailto:jef at norbit.de>> wrote:
>> > Hi Jonathan,
>> > On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
>> > > QGIS 2.2 has a confirmation dialog when I go to remove a
>> > layer; Maybe
>> > > it's me but I'm sure the previous versions didn't -
>> > alternately I can't
>> > > find a setting anywhere to turn this behaviour off (I'm
>> > assuming I did in
>> > > the past if it was there).
>> > > Is this a new feature or have I just lost the setting?
>> > Personally I find it
>> > > quite annoying so would like to disable it.
>> > See #9094[1]
>> > Jürgen
>> > [1] http://hub.qgis.org/issues/9094
>> > Jürgen E. Fischer norBIT GmbH Tel.
>> > +49-4931-918175-31
>> > Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> > +49-4931-918175-50
>> > Software Engineer D-26506 Norden
>> > http://www.norbit.de
>> > QGIS PSC member (RM) Germany IRC: jef
>> > on FreeNode
>> > norBIT Gesellschaft fuer Unternehmensberatung und
>> > Informationssysteme mbH
>> > Rheinstrasse 13, 26506 Norden
>> > GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > This transmission is intended for the named addressee(s) only and
>> > may contain sensitive or protectively marked material up to
>> > RESTRICTED and should be handled accordingly. Unless you are the
>> > named addressee (or authorised to receive it for the addressee) you
>> > may not copy or use it, or disclose it to anyone else. If you have
>> > received this transmission in error please notify the sender
>> > immediately. All email traffic sent to or from us, including without
>> > limitation all GCSX traffic, may be subject to recording and/or
>> > monitoring in accordance with relevant legislation.
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140226/474620a2/attachment.html>
