[Qgis-user] QGIS 2.2 - Remove layer dialog
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Feb 26 04:30:05 PST 2014
Hi Andreas,
Thanks for the explanation. My take-home from trying to read the thread was
that they had been implemented; apparently they haven't (for the reasons
you clearly explained).
So a reading comprehension issue on my part. Sorry for the noise.
Thanks for the clarification.
Cheers,
Jonathan
On 26 February 2014 12:19, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Jonathan,
> Delete and backspace is not so easy to implement on the layer tree I
> assume. We are dealing with multiple platforms, not only Windows. On
> Linux, for example there is a notion of "focus" that behaves different
> from Windows - a delete key when the mouse cursor is above the map area
> can mean something different as a delete key above the layer tree.
> People may accidentally hit the delete key while the mouse cursor is
> above some other panel/area.
> Removing something as important as a layer or group, where potentially a
> lot of work goes into configuring it, shouldn't just be deleted by
> hitting the delete, while perhaps accidentally the mouse cursor is above
> the layer tree.
> Then there are mac users where there is no "delete" key on the keyboard
> and it has to be emulated by shift-backspace.
> It is not so easy to handle all theses platforms equally well.
> Andreas
> > Also, no-one has commented on the fact that delete and Backspace don't
> seem
> > to work for me in 2.2. Do they work for others?
> > Just my thupence. :-)
> > Cheers,
> > Jonathan
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140226/e2ab8fa5/attachment.html>
