[Qgis-user] Run-time error R6034
Lester Anderson arctica1963 at gmail.com
Wed Feb 26 22:32:18 PST 2014
Think the next step is to test whether the 32-bit version exhibits this
issue or not. Never had this problem with v1.8.
Still get the same issue if you go through OSgeo4W method. As I say, need
to verify if it is just the 64 bit version or both!
Cheers
Lester
On 27 February 2014 05:56, Tijan49 <tijan49 at yahoo.fr> wrote:
>  Hello,
> I have exactly the same bug, with apparently no more consequences later.
> Thanks,
> Jean
> Le 26/02/2014 23:58, Lester Anderson a écrit :
>    Hello
>  I have installed version 2.2 of QGIS from the stand-alone installer for
> Windows 64-bit and it is still giving the same run-time error that 2.0.1
> did on starting the program. As before, this does not affect the program
> but clearly was not addressed:
>  No idea what the program is trying to do, put it is on the start up phase
> where it is restoring loaded plugins.
>  Still a bug to me.
>  Cheers
>  Lester
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140227/4c2c4a8c/attachment.html>
