[Qgis-user] Calculating acreage in 2.2
Randal Hale rjhale at northrivergeographic.com
Thu Feb 27 09:00:29 PST 2014
I think I may have found a bug....or I'm just slightly confused.
I'm working on a client job (digitizing forestry stands) and I need to
calculate acres of the final area. The data I'm working with is in
EPSG:2274. So I create a field that is decimal (width 20, precision 5)
and in the field calculator I use $area/43560 - (there are 43560 square
feet in an acre). My result is one decimal off - instead of 195.30 acres
I have 19.53 Acres. I've done this enough to where I'm questioning every
button push. If I divide by 4356 I get the correct number. I'm currently
doing this in Windows 7 OSGEO install QGIS 2.2.
Anyway - can someone tell me I'm crazy...or not crazy. Projections are
set correctly...cat has remained off the keyboard etc.
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
http://about.me/rjhale
