[Qgis-user] How to set posgis default sequential value in a QGIS "editable" view?
Alexandre Neto senhor.neto at gmail.com
Fri Feb 28 08:03:37 PST 2014
Hello all,
I have posted this question in gis.stackexchage, does anyone have a
solution for it?
Thanks
http://goo.gl/Bp6xZN
*Introduction*
In a QGIS project I have a VIEW, that I want to became editable (I'm trying
to replicate the versioning system used DB Manager with some tweeks).
Therefore I created a few rules to make is so (see below). I'm able to
delete and update the features without problems, but while inserting new
features, I'm not being able to use postgis default value (sequence) for
gid (that in this case is not a primary key) but has a NOT NULL constraint.
So, if the user don't fill the gid value, qgis is not be able to commit the
changes, if it does... we neve know where thing going to get wrong.
*The question*
Is there a way I can prepare my view or set qgis form to read the default
value?
*What I got*
-- The original tableCREATE TABLE "PGHP".infraestruturas(
  gid serial,
  nome character varying(40),
  classe character varying(40),
  geom geometry(POINT, 3763),
  "id_hist" serial primary key,
  "time_start" timestamp,
  "time_end" timestamp,
  "user_update" character varying(40));
-- Creating the viewCREATE OR REPLACE VIEW "PGHP".infra_portoes AS
  SELECT "gid", "nome", "geom"::Geometry(POINT, 3763), "time_start",
"user_update"
  FROM "PGHP"."infraestruturas_pontos"
  WHERE "classe" = 'portoes' AND "time_end" IS NULL;
-- Make the view editableCREATE OR REPLACE RULE "_DELETE" AS ON DELETE
TO "PGHP".infra_portoes DO INSTEAD
  DELETE FROM "PGHP"."infraestruturas_pontos" WHERE gid = old.gid;
CREATE OR REPLACE RULE "_INSERT" AS ON INSERT TO "PGHP".infra_portoes DO INSTEAD
  INSERT INTO "PGHP"."infraestruturas_pontos" ("gid","classe","nome","geom")
    VALUES (NEW."gid",'portoes',NEW."nome",NEW."geom");
CREATE OR REPLACE RULE "_UPDATE" AS ON UPDATE TO "PGHP".infra_portoes DO INSTEAD
  UPDATE "PGHP"."infraestruturas" SET
    "gid" = NEW."gid",
    "classe" = 'portoes',
    "nome" = NEW."nome",
    "geom" = NEW."geom"
  WHERE gid = NEW.gid;
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140228/99048124/attachment.html>
