[Qgis-user] QGIS 2.0.1: Missing source encoding codecs
William Kyngesburye woklist at kyngchaos.com
Sun Jan 5 10:08:17 PST 2014
With my QGIS 2.0.1 (release) package, on both OS X 10.7.5 and 10.8.5, I get the full encoding menu, including SJIS.  Dakarto uses the same Qt I think (4.8.5), as well as my frameworks (GDAL).  Maybe there's a bug in QGIS dev, try my release package to see if you still have the problem.
About that homebrew GDAL - are you replacing my GDAL framework with that (does homebrew even have the framework build option for GDAL?)?  Dakarto's QGIS should be using my GDAL framework.  If you're replacing it, maybe something is wrong there, so try restoring my GDAL.  (why replace GDAL?)
On Jan 5, 2014, at 9:37 AM, Akihiro Takemura wrote:
> As it happens, unchecking "Ignore shapefile declaration" and SHAPE_ENCODING=CP932 fixed the issue where attributes are displayed incorrectly.
> I've actually noticed that the number of encoding in the dropdown list is actually *less* than the number available through QTextCodec.availableCodecs().
> There are 134 encodings in QtCore.availableCodecs(), but only 116 (as far as I could count, sorry if mistaken) in the source file encodings list in QGIS. Actually, all encodings at 117th to 134th position in the list are missing, so things like GB18030, GBK, GB2312 are missing, which suggests that the list is getting truncated somewhere.
> Qgis-user mailing list
