[Qgis-user] Newbie - QGIS won't recongize shp files, comp turns shp files into pdfs
Alexandre Neto senhor.neto at gmail.com
Mon Jan 6 02:24:52 PST 2014
Also, confirm that you have the complete set of files of shapefile.
You must have (at least) a .SHP, a .SHX and a .DBF with the same name.
Best regards,
Alexandre Neto
On Mon, Jan 6, 2014 at 6:00 AM, Frank Sokolic <sokolic at worldonline.co.za>wrote:
> Hi Matt,
> Are you using the "Add Vector Layer" command to open the shapefiles? If
> not, go to the "Layer" menu and select the "Add Vector Layer" command. You
> can then choose "Browse" to look for the shapefile you want to load.
> Regards, Frank.
> On 06/01/2014 06:57, Matt_Klick wrote:
>> No luck on this yet, but thank you for your suggestion. On another
>> computer, I still cannot upload shp files - instead changing them to
>> nursoft (??) files. In any event, I cannot yet open a shp file using QGIS.
>> On Fri, Jan 3, 2014 at 3:19 PM, Akinyemi Bojerenu [via OSGeo.org]
>> <[hidden email] </user/SendEmail.jtp?type=node&node=5096495&i=0>> wrote:
>>     Hi,
>>     Please extract the contents of the zip file first into a destination
>>     folder of choice.
>>     When opening a shapefile, navigate to your folder to select the
>>     shapefile(s).
>>     Hope this helps..
>>     Yemi
>>     On Jan 4, 2014 9:13 AM, "Matt_Klick" <[hidden email]
>>     <http://user/SendEmail.jtp?type=node&node=5096323&i=0>> wrote:
>>         I'm very new to any GIS type platforms, so please forgive the
>>         ignorance on
>>         display here (and I did search for answers to this elsewhere).
>> I've
>>         downloaded QGIS 2.0.1. I separately downloaded Tunisia
>>         administrative data
>>         from DIVA-GIS. When I open QGIS, it does not find the .zip file,
>>         nor any of
>>         the shp files. In my efforts to correct, I managed to convert
>>         shp files into
>>         pdfs. Even though I've re-installed QGIS, and deleted and
>>         re-downloaded
>>         Tunisia files, shp files are once again pdfs, and QGIS cannot
>>         "see" any shp
>>         files. Any advice, or thoughts on what I'm doing wrong, greatly
>>         appreciated.
>>         -MK
>>         View this message in context:
>>         http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-
>> recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322.html
>>         Sent from the Quantum GIS - User mailing list archive at
>> Nabble.com.
>>         _______________________________________________
>>         Qgis-user mailing list
>>         [hidden email]
>>         <http://user/SendEmail.jtp?type=node&node=5096323&i=1>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     [hidden email] <http://user/SendEmail.jtp?type=node&node=5096323&i=2>
>>     If you reply to this email, your message will be added to the
>>     discussion below:
>> recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096323.html
>>     To unsubscribe from Newbie - QGIS won't recongize shp files, comp
>>     turns shp files into pdfs, click here.
>>     NAML
>>     <http://osgeo-org.1560.x6.nabble.com/template/
>> NamlServlet.jtp?macro=macro_viewer&id=instant_html%
>> 21nabble%3Aemail.naml&base=nabble.naml.namespaces.
>> BasicNamespace-nabble.view.web.template.NabbleNamespace-
>> nabble.view.web.template.NodeNamespace&breadcrumbs=
>> notify_subscribers%21nabble%3Aemail.naml-instant_emails%
>> 21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Newbie - QGIS won't recongize shp
>> <http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-
>> recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096495.html
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140106/74f3cd9f/attachment.html>
