[Qgis-user] Newbie - QGIS won't recongize shp files, comp turns shp files into pdfs
Matt_Klick matthew.klick at gmail.com
Mon Jan 6 08:37:06 PST 2014
Thank you both Frank and Alexandre,
It is appreciated.
I'm afraid I am using both the add vector layer, and have the complete set
of files downloaded, and still no luck -- and now on several computers and
having reinstalled QGIS, and having re-downloaded files, a half dozen times
at least.
I have only been using files downloaded from DIVA-GIS though, so perhaps I
will try getting fields from somewhere else.
Best, M
On Mon, Jan 6, 2014 at 3:26 AM, Sr. Neto [via OSGeo.org] <
ml-node+s1560n5096521h88 at n6.nabble.com> wrote:
> Also, confirm that you have the complete set of files of shapefile.
> You must have (at least) a .SHP, a .SHX and a .DBF with the same name.
> Best regards,
> Alexandre Neto
> On Mon, Jan 6, 2014 at 6:00 AM, Frank Sokolic <[hidden email]<http://user/SendEmail.jtp?type=node&node=5096521&i=0>
> > wrote:
>> Hi Matt,
>> Are you using the "Add Vector Layer" command to open the shapefiles? If
>> not, go to the "Layer" menu and select the "Add Vector Layer" command. You
>> can then choose "Browse" to look for the shapefile you want to load.
>> Regards, Frank.
>> On 06/01/2014 06:57, Matt_Klick wrote:
>>> No luck on this yet, but thank you for your suggestion. On another
>>> computer, I still cannot upload shp files - instead changing them to
>>> nursoft (??) files. In any event, I cannot yet open a shp file using
>>> QGIS.
>>> On Fri, Jan 3, 2014 at 3:19 PM, Akinyemi Bojerenu [via OSGeo.org]
>>> <[hidden email] </user/SendEmail.jtp?type=node&node=5096495&i=0>> wrote:
>>>     Hi,
>>>     Please extract the contents of the zip file first into a destination
>>>     folder of choice.
>>>     When opening a shapefile, navigate to your folder to select the
>>>     shapefile(s).
>>>     Hope this helps..
>>>     Yemi
>>>     On Jan 4, 2014 9:13 AM, "Matt_Klick" <[hidden email]
>>>     <http://user/SendEmail.jtp?type=node&node=5096323&i=0>> wrote:
>>>         I'm very new to any GIS type platforms, so please forgive the
>>>         ignorance on
>>>         display here (and I did search for answers to this elsewhere).
>>> I've
>>>         downloaded QGIS 2.0.1. I separately downloaded Tunisia
>>>         administrative data
>>>         from DIVA-GIS. When I open QGIS, it does not find the .zip file,
>>>         nor any of
>>>         the shp files. In my efforts to correct, I managed to convert
>>>         shp files into
>>>         pdfs. Even though I've re-installed QGIS, and deleted and
>>>         re-downloaded
>>>         Tunisia files, shp files are once again pdfs, and QGIS cannot
>>>         "see" any shp
>>>         files. Any advice, or thoughts on what I'm doing wrong, greatly
>>>         appreciated.
>>>         -MK
>>>         View this message in context:
>>>         http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-
>>> recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322.html
>>>         Sent from the Quantum GIS - User mailing list archive at
>>> Nabble.com.
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         [hidden email]
>>>         <http://user/SendEmail.jtp?type=node&node=5096323&i=1>
>>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>     [hidden email] <http://user/SendEmail.jtp?type=node&node=5096323&i=2
>>>     If you reply to this email, your message will be added to the
>>>     discussion below:
>>> tp5096322p5096323.html
>>>     To unsubscribe from Newbie - QGIS won't recongize shp files, comp
>>>     turns shp files into pdfs, click here.
>>>     NAML
>>>     <http://osgeo-org.1560.x6.nabble.com/template/
>>> NamlServlet.jtp?macro=macro_viewer&id=instant_html%
>>> 21nabble%3Aemail.naml&base=nabble.naml.namespaces.
>>> BasicNamespace-nabble.view.web.template.NabbleNamespace-
>>> nabble.view.web.template.NodeNamespace&breadcrumbs=
>>> notify_subscribers%21nabble%3Aemail.naml-instant_emails%
>>> 21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>> View this message in context: Re: Newbie - QGIS won't recongize shp
>>> <http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-
>>> tp5096322p5096495.html>
>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>>> Nabble.com.
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096521&i=1>
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096521&i=2>
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096521&i=3>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096521.html
>  To unsubscribe from Newbie - QGIS won't recongize shp files, comp turns
> shp files into pdfs, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5096322&code=bWF0dGhldy5rbGlja0BnbWFpbC5jb218NTA5NjMyMnwtMTkxMzIxODg3Nw==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096580.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140106/427e0066/attachment.html>
