[Qgis-user] Shifting overlapping points
Alexander Bruy alexander.bruy at gmail.com
Mon Jan 6 05:33:51 PST 2014
Maybe your QGIS is too old. This algorithm was added after
releasing QGIS 2.0.1.
You can upgrade Processing plugin via Plugin manager or,
alternatively, install nightly build of QGIS.
2014/1/6 Martin Gibson <martin at creativeinterpretation.co.uk>:
> Thanks Alexander.  I can't see points displacement on my install.  Under
> QGIS Geoalgorithms → Vector
> geometry tools I have 18 algorithms available to me, but not that one.  Will
> investigate further to see if I can find why it is missing.
> Martin
> On 6 January 2014 12:52, Alexander Bruy <alexander.bruy at gmail.com> wrote:
>> Hi Martin,
>> > Hi,
>> > I'm more familiar with ArcGIS than QGIS but starting to shift over to
>> > using
>> > QGIS for most/all work. One thing I had been using QGIS for anyway was
>> > shifting overlaid points, as I couldn't get Arc to do this.  I was using
>> > the
>> > ShiftPoints plugin, but it doesn't appear to be available for 2.0 - I
>> > have
>> > come across a statement that it obsolete now and that I should use
>> > Sextante
>> > instead.  Can't find any info on how to achieve what I used to with the
>> > plugin - can anyone help?
>> ShiftPoints plugin now not supported as its functionality already
>> available via Processing (Analysis menu). You can find this algorithm
>> in the Processing toolbox under QGIS Geoalgorithms → Vector
>> geometry tools → Point displacement.
>> Alternatively you can use search box in the top of Procesing toolbox
>> and type something like "disp". List of algorithms will be filtered to
>> match your query.
>> Hope this helps
>> Alexander Bruy
> Martin Gibson
> Creative Interpretation Ltd
> w: www.creativeinterpretation.co.uk
> e: martin at creativeinterpretation.co.uk
> t:  01983 220044
> Creative Interpretation Ltd is a company registered in England and Wales
> number 07963113, registered office 145-157 St John Street, London, EC1V 4PW.
> Qgis-user mailing list
Alexander Bruy
