[Qgis-user] QGIS Georeferencer and Transparency
Siki Zoltan siki at agt.bme.hu
Tue Jan 7 12:26:46 PST 2014
Dear Andreas,
try Raster | Extraction | Clipper with a mask layer and alpha band.
Regards,
Zoltan
On Tue, 7 Jan 2014, Andreas Neumann wrote:
> Hi,
> Some of my maps I georeference are rotated approx. 45 degrees because
> they did not point to the north before georeferencing. This is desired -
> however - the resulting file has a huge black background as a result of
> the rotation.
> I tried with the option "use 0 for transparency if necessary" - which
> helped - but the map already contains black pixels and the result is
> that I have a lot of tiny transparent pixels in the map, next to the
> transparent background I wanted. Is there a way to set this transparency
> to a custom RGB value that I know it is not yet used within the map?
> Thank you for any ideas.
> Andreas
> Qgis-user mailing list
