[Qgis-user] Map composer - Transparency in legend symbols
Morgan, David
david.morgan at pembrokeshire.gov.uk
Wed Jan 8 00:56:56 PST 2014
If you have received this email in error, please notify us by telephone on 01437 764551 and delete it from your computer immediately. Os ydych chi wedi derbyn yr e-bost hwn trwy gamgymeriad, byddwch cystal â rhoi gwybod inni trwy ffonio 01437 764551. Wedyn dylech ddileu’r e-bost ar unwaith oddi ar eich cyfrifiadur.
Hi Paolo
There are two transparency sliders in the style dialog. Altering the big
one at the top doesn't affect the transparency of the legend symbol or
the style preview in the dialog, but the small transparency slider below
the size unit selector does (at least for me - v2.0.1, windows XP).
Dave
Message: 10
Date: Tue, 07 Jan 2014 17:53:47 +0100
To: QGIS mailing list <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Map composer - Transparency in legend symbols
Message-ID: <52CC311B.4030902 at tiscali.it>
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Hello list,
I have a question regarding the map composer.
I often use vector layers with simple fills and a transparency level set
(es. 50%) in order to show underlying features.
When you compose a map including layers with a transparency level set,
the symbols in the legend won't reflect the transparency level of the
matching layer. So the symbols in the legend will show the fill color at
100% saturation while the map shows the same color, but with a lower
level of saturation.
This makes matching the symbols in the legend with those on the map
harder.
I see that you can give the legend a degree of transparency, but that
will also affect text and other elements of the legend as well.
Is there a workaround for this (lesser) problem?
Paolo Caporro
This document should only be read by those persons to whom it is addressed, and be used by them for its intended purpose; and must not otherwise be reproduced, copied, disseminated, disclosed, modified, distributed, published or actioned. If you have received this email in error, please notify us immediately by telephone on 01437 764551 and delete it from your computer immediately. This email address must not be passed on to any third party nor be used for any other purpose.
Pembrokeshire County Council Website - http://www.pembrokeshire.gov.uk
Please Note: Incoming and outgoing e-mail messages are routinely monitored for compliance with our IT Security, and Email/Internet Policy.
This signature also confirms that this email message has been swept for the presence of computer viruses and malicious code.
Dim ond y sawl y mae'r ddogfen hon wedi'i chyfeirio atynt ddylai ei darllen, a'i defnyddio ganddynt ar gyfer ei dibenion bwriadedig; ac ni ddylid fel arall ei hatgynhyrchu, copio, lledaenu, datgelu, addasu, dosbarthu, cyhoeddi na'i rhoi ar waith chwaith. Os ydych chi wedi derbyn yr e-bost hwn trwy gamgymeriad, byddwch cystal a rhoi gwybod i ni ar unwaith trwy ffonio 01437 764551 a'i ddileu oddi ar eich cyfrifiadur ar unwaith. Ni ddylid rhoi'r cyfeiriad e-bost i unrhyw drydydd parti na'i ddefnyddio ar gyfer unrhyw ddiben arall chwaith.
Gwefan Cyngor Sir Penfro - http://www.pembrokeshire.gov.uk
Sylwer: Mae negeseuon e-bost sy’n cael eu hanfon a’u derbyn yn cael eu monitro’n rheolaidd ar gyfer cydymffurfio â’n Diogelwch TG, a’n Polisi E-bost/Rhyngrwyd.
Mae'r llofnod hwn hefyd yn cadarnhau bod y neges e-bost hon wedi cael ei harchwilio am fodolaeth firysau cyfrifiadurol a chod maleisus.
