[Qgis-user] Terrain Profile Tool
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jan 10 08:54:30 PST 2014
There is a bug in matplotlib, see bug report below with simple fix for
matplotlib. If you use qwt instead, you can export without problems.
http://hub.qgis.org/issues/9055
On Fri, Jan 10, 2014 at 1:22 PM, Edita Laurinaviciute <
edita.laurinaviciute at opw.ie> wrote:
> Thanks Etienne.
> But I can't find any function to export the graph?
> I can save a profile graph as an image via Print Scr and Paint and then
> add to composer.
> Is there straight way to do this?
> Thanks.
> Edita
> On 10/01/2014 14:28, Etienne Tourigny wrote:
> I guess you could export the profile graph as an image, then add that
> image in the composer.
> cheers
> Etienne
> On Fri, Jan 10, 2014 at 11:12 AM, Edita Laurinaviciute <
>> Hi List,
>> How could I add Terrain profile graph on the composer?
>> Many Thanks,
>> Edita
>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140110/3ab8033d/attachment.html>
