[Qgis-user] qgis2threejs plugin demo
venerio giuseppe anardu
anardu.geol at yahoo.it
Sat Jan 11 10:17:51 PST 2014
Thank you,
just installed manually, now it works!
Il Sabato 11 Gennaio 2014 2:19, Szabo Szilard <szaboszilard.geo at gmail.com> ha scritto:
Hi Giovanni and Vincent,
Now it works fine for me, too. Thanks for your help.
Best regards, Szilard
2014/1/10 Vincent Picavet <vincent.ml at oslandia.com>
Hello,
>Le vendredi 10 janvier 2014 16:29:21, venerio giuseppe anardu a écrit :
>> Hello,
>> I've got the same problem: no vertical exageration option can be found in
>> any setting dialog. Greetings
>This option is only available in the latest development version.
>You have to download the project from github and install it by hand to find
>this option.
>Vincent
>> Giuseppe Anardu
>> Il Giovedì 9 Gennaio 2014 23:49, G. Allegri <giohappy at gmail.com> ha
>> scritto:
>> Hi Szilard,
>> I premit that the plugin is not mine.
>> I've installed it using the zip downloaded from the repository and it
>> worked fine. I don't know what's going wrong for you. Have you tried to
>> completely remove the original plugin and replacing it, totally, with the
>> one unzipped from github?
>> 2014/1/9 Szabo Szilard <szaboszilard.geo at gmail.com>
>> Thanks Giovanni,
>> >I have tried the downloading but it crashed the plugin with the simple
>> >overwriting. I tried it with replacing all the data you had at the github
>> >and trying to replace some files seeming to be relevant. Obviously, I am
>> >doing something wrong; however, I can wait for the official upgrade, too.
>> >Thanks again,
>> >Szilard
>> >2014/1/8 G. Allegri <giohappy at gmail.com>
>> >I mean the main dialog.
>> >>Probably you don't see the exaggeration option because it was added a few
>> >>days ago. You should the plugin from GitHub and replace yours.
>> >>giovanni
>> >>Il 08/gen/2014 23:14 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha
>> >>scritto:
>> >>It seems that I have no settings dialog - or just simply am I seeking it
>> >>at a wrong place?
>> >>>Thanks,
>> >>>Szilard
>> >>>Yes, it's possible through the settings dialog.
>> >>>>giovanni
>> >>>>Il 08/gen/2014 22:59 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha
>> >>>>scritto:
>> >>>>Hi Michael,
>> >>>>>Thank You for the demo and the video, I did not know this plugin yet.
>> >>>>>Is there a possibility to set the vertical exaggregation? I usually
>> >>>>>work on plain areas and the default settings not seem to be enough to
>> >>>>>visualize the slight differences of the elevation. Did you meet this
>> >>>>>kind of issue?
>> >>>>>Thanks in advance,
>> >>>>>Szilard
>> >>>>>2014/1/6 kimaidou <kimaidou at gmail.com>
>> >>>>>Hi all
>> >>>>>>I just discovered the plugin qgis2threejs. I love its simple yet
>> >>>>>>powerfull concept : export QGIS canvas as an image and drap it on a
>> >>>>>>3D model based on some DEM elayer. I set up a demo and a video
>> >>>>>>tutorial to show how it can be used :
>> >>>>>>* video tutorial : https://vimeo.com/83511028
>> >>>>>>* live demo : http://demo.3liz.com/demo_qgis2threejs/output.html
>> >>>>>>Thanks to the author !
>> >>>>>>Michael
>> >>>>>>_______________________________________________
>> >>>>>>Qgis-user mailing list
>> >>>>>>Qgis-user at lists.osgeo.org
>> >>>>>>http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Szilard SZABO
associate professor, head of department
Department of Physical Geography and Geoinformation Systems
University of Debrecen
http://www.mendeley.com/profiles/szilard-szabo/
Publications
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140111/14428fea/attachment.html>
