[Qgis-user] qgis2threejs plugin demo
Szabo Szilard
szaboszilard.geo at gmail.com
Fri Jan 10 07:50:23 PST 2014
Hi Giovanni and Vincent,
Now it works fine for me, too. Thanks for your help.
Best regards, Szilard
2014/1/10 Vincent Picavet <vincent.ml at oslandia.com>
> Hello,
> Le vendredi 10 janvier 2014 16:29:21, venerio giuseppe anardu a écrit :
> > Hello,
> > I've got the same problem: no vertical exageration option can be found in
> > any setting dialog. Greetings
> This option is only available in the latest development version.
> You have to download the project from github and install it by hand to find
> this option.
> Vincent
> > Giuseppe Anardu
> > Il Giovedì 9 Gennaio 2014 23:49, G. Allegri <giohappy at gmail.com> ha
> > scritto:
> > Hi Szilard,
> > I premit that the plugin is not mine.
> > I've installed it using the zip downloaded from the repository and it
> > worked fine. I don't know what's going wrong for you. Have you tried to
> > completely remove the original plugin and replacing it, totally, with the
> > one unzipped from github?
> > 2014/1/9 Szabo Szilard <szaboszilard.geo at gmail.com>
> > Thanks Giovanni,
> > >I have tried the downloading but it crashed the plugin with the simple
> > >overwriting. I tried it with replacing all the data you had at the
> github
> > >and trying to replace some files seeming to be relevant. Obviously, I am
> > >doing something wrong; however, I can wait for the official upgrade,
> too.
> > >Thanks again,
> > >Szilard
> > >2014/1/8 G. Allegri <giohappy at gmail.com>
> > >I mean the main dialog.
> > >>Probably you don't see the exaggeration option because it was added a
> few
> > >>days ago. You should the plugin from GitHub and replace yours.
> > >>giovanni
> > >>Il 08/gen/2014 23:14 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha
> > >>scritto:
> > >>It seems that I have no settings dialog - or just simply am I seeking
> it
> > >>at a wrong place?
> > >>>Thanks,
> > >>>Szilard
> > >>>Yes, it's possible through the settings dialog.
> > >>>>giovanni
> > >>>>Il 08/gen/2014 22:59 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha
> > >>>>scritto:
> > >>>>Hi Michael,
> > >>>>>Thank You for the demo and the video, I did not know this plugin
> yet.
> > >>>>>Is there a possibility to set the vertical exaggregation? I usually
> > >>>>>work on plain areas and the default settings not seem to be enough
> to
> > >>>>>visualize the slight differences of the elevation. Did you meet this
> > >>>>>kind of issue?
> > >>>>>Thanks in advance,
> > >>>>>Szilard
> > >>>>>2014/1/6 kimaidou <kimaidou at gmail.com>
> > >>>>>Hi all
> > >>>>>>I just discovered the plugin qgis2threejs. I love its simple yet
> > >>>>>>powerfull concept : export QGIS canvas as an image and drap it on a
> > >>>>>>3D model based on some DEM elayer. I set up a demo and a video
> > >>>>>>tutorial to show how it can be used :
> > >>>>>>* video tutorial : https://vimeo.com/83511028
> > >>>>>>* live demo : http://demo.3liz.com/demo_qgis2threejs/output.html
> > >>>>>>Thanks to the author !
> > >>>>>>Michael
> > >>>>>>_______________________________________________
> > >>>>>>Qgis-user mailing list
> > >>>>>>Qgis-user at lists.osgeo.org
> > >>>>>>http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Szilard SZABO
associate professor, head of department
Department of Physical Geography and Geoinformation Systems
University of Debrecen
http://www.mendeley.com/profiles/szilard-szabo/
Publications <https://vm.mtmt.hu/search/slist.php?lang=0&AuthorID=10000172>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140110/19b83f12/attachment.html>
