[Qgis-user] qgis2threejs plugin demo
Vincent Picavet vincent.ml at oslandia.com
Fri Jan 10 07:40:33 PST 2014
Hello,
Le vendredi 10 janvier 2014 16:29:21, venerio giuseppe anardu a écrit :
> Hello,
> I've got the same problem: no vertical exageration option can be found in
> any setting dialog. Greetings
This option is only available in the latest development version.
You have to download the project from github and install it by hand to find
this option.
Vincent
> Giuseppe Anardu
> Il Giovedì 9 Gennaio 2014 23:49, G. Allegri <giohappy at gmail.com> ha
> scritto:
> Hi Szilard,
> I premit that the plugin is not mine.
> I've installed it using the zip downloaded from the repository and it
> worked fine. I don't know what's going wrong for you. Have you tried to
> completely remove the original plugin and replacing it, totally, with the
> one unzipped from github?
> 2014/1/9 Szabo Szilard <szaboszilard.geo at gmail.com>
> Thanks Giovanni,
> >I have tried the downloading but it crashed the plugin with the simple
> >overwriting. I tried it with replacing all the data you had at the github
> >and trying to replace some files seeming to be relevant. Obviously, I am
> >doing something wrong; however, I can wait for the official upgrade, too.
> >Thanks again,
> >Szilard
> >2014/1/8 G. Allegri <giohappy at gmail.com>
> >I mean the main dialog.
> >>Probably you don't see the exaggeration option because it was added a few
> >>days ago. You should the plugin from GitHub and replace yours.
> >>giovanni
> >>Il 08/gen/2014 23:14 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha
> >>scritto:
> >>It seems that I have no settings dialog - or just simply am I seeking it
> >>at a wrong place?
> >>>Thanks,
> >>>Szilard
> >>>Yes, it's possible through the settings dialog.
> >>>>giovanni
> >>>>Il 08/gen/2014 22:59 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha
> >>>>scritto:
> >>>>Hi Michael,
> >>>>>Thank You for the demo and the video, I did not know this plugin yet.
> >>>>>Is there a possibility to set the vertical exaggregation? I usually
> >>>>>work on plain areas and the default settings not seem to be enough to
> >>>>>visualize the slight differences of the elevation. Did you meet this
> >>>>>kind of issue?
> >>>>>Thanks in advance,
> >>>>>Szilard
> >>>>>2014/1/6 kimaidou <kimaidou at gmail.com>
> >>>>>Hi all
> >>>>>>I just discovered the plugin qgis2threejs. I love its simple yet
> >>>>>>powerfull concept : export QGIS canvas as an image and drap it on a
> >>>>>>3D model based on some DEM elayer. I set up a demo and a video
> >>>>>>tutorial to show how it can be used :
> >>>>>>* video tutorial : https://vimeo.com/83511028
> >>>>>>* live demo : http://demo.3liz.com/demo_qgis2threejs/output.html
> >>>>>>Thanks to the author !
> >>>>>>Michael
> >>>>>>_______________________________________________
> >>>>>>Qgis-user mailing list
> >>>>>>Qgis-user at lists.osgeo.org
> >>>>>>http://lists.osgeo.org/mailman/listinfo/qgis-user
