[Qgis-user] qgis2threejs plugin demo
venerio giuseppe anardu
anardu.geol at yahoo.it
Fri Jan 10 07:29:21 PST 2014
Hello,
I've got the same problem: no vertical exageration option can be found in any setting dialog.
Greetings
Giuseppe Anardu
Il Giovedì 9 Gennaio 2014 23:49, G. Allegri <giohappy at gmail.com> ha scritto:
Hi Szilard,
I premit that the plugin is not mine.
I've installed it using the zip downloaded from the repository and it worked fine. I don't know what's going wrong for you. Have you tried to completely remove the original plugin and replacing it, totally, with the one unzipped from github?
2014/1/9 Szabo Szilard <szaboszilard.geo at gmail.com>
Thanks Giovanni,
>I have tried the downloading but it crashed the plugin with the simple overwriting. I tried it with replacing all the data you had at the github and trying to replace some files seeming to be relevant.
>Obviously, I am doing something wrong; however, I can wait for the official upgrade, too.
>Thanks again,
>SzilardÂ
>2014/1/8 G. Allegri <giohappy at gmail.com>
>I mean the main dialog.
>>Probably you don't see the exaggeration option because it was added a few days ago.
>>You should the plugin from GitHub and replace yours.
>>giovanni
>>Il 08/gen/2014 23:14 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha scritto:
>>It seems that I have no settings dialog - or just simply am I seeking it at a wrong place?
>>>Thanks,
>>>Szilard
>>>Yes, it's possible through the settings dialog.
>>>>giovanni
>>>>Il 08/gen/2014 22:59 "Szabo Szilard" <szaboszilard.geo at gmail.com> ha scritto:
>>>>Hi Michael,
>>>>>Thank You for the demo and the video, I did not know this plugin yet.
>>>>>Is there a possibility to set the vertical exaggregation? I usually work on plain areas and the default settings not seem to be enough to visualize the slight differences of the elevation. Did you meet this kind of issue?
>>>>>Thanks in advance,
>>>>>Szilard
>>>>>2014/1/6 kimaidou <kimaidou at gmail.com>
>>>>>Hi all
>>>>>>I just discovered the plugin qgis2threejs. I love its simple yet powerfull concept : export QGIS canvas as an image and drap it on a 3D model based on some DEM elayer. I set up a demo and a video tutorial to show how it can be used :
>>>>>>* video tutorial : https://vimeo.com/83511028
>>>>>>* live demo : http://demo.3liz.com/demo_qgis2threejs/output.html
>>>>>>Thanks to the author !
>>>>>>Michael
>>>>>>_______________________________________________
>>>>>>Qgis-user mailing list
>>>>>>Qgis-user at lists.osgeo.org
>>>>>>http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>Dr. Szilard SZABO
>>>associate professor, head of department
>>>Department of Physical Geography and Geoinformation Systems
>>>University of Debrecen
>>>http://www.mendeley.com/profiles/szilard-szabo/
>>>Publications
>Dr. Szilard SZABO
>Publications
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140110/b6dc9554/attachment.html>
