[Qgis-user] Print Composer
Andreas Neumann a.neumann at carto.net
Mon Jan 13 05:16:18 PST 2014
The "Move Item Content" works only for items that have a movable
content. As far as I know the map is the only object that has a movable
content currently.
For the movement of all other objects you should use the "Select/Move
Item" button.
Andreas
Am 13.01.2014 14:09, schrieb Craig Leat:
> Ah, I can see how I missed this. I was expecting a "hand" icon with a label
> "pan". BTW "Move Item Content" doesn't appear to work with all items. For
> example, I can't move a label within it's frame.
> Thanks Andreas for the pointer to the blog for upcoming improvements. I'll
> take a closer look.
> Regards
> Craig
