[Qgis-user] Print Composer
Andreas Neumann a.neumann at carto.net
Mon Jan 13 04:43:23 PST 2014
Hi Craig,
You can pan with the "Move item content" button.
There is no rotation linked with the mouse, just the zooming.
What would you propose - how should rotation of the map work? In
combination with a modifier key?
Please also note that the print composer will be considerably improved
in QGIS 2.2. See Nyall's work and blog:
http://nyalldawson.net/
Blog entries with composer improvements, parts 1-3. You can already try
that out in the developer version 2.1 available through the OSGeo4W
installer.
Andreas
Am 13.01.2014 13:19, schrieb Craig Leat:
> Hi,
> I have recently upgraded to QGIS 2 am i'm really enjoying it!
> I have noticed I can zoom within a map frame in the Print Composer with the
> mouse wheel. Is there a way to pan within the frame? The ability to zoom,
> pan and rotate with a mouse within the map frame would be fantastic.
> Regards
> Craig
> Qgis-user mailing list
