[Qgis-user] QGIS Georeferencer and Transparency
Paolo Cavallini cavallini at faunalia.it
Mon Jan 13 22:35:20 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 13/01/2014 22:05, Jukka Rahkonen ha scritto:
> Don't let QGIS to do the warping but just push the button and create the
> GDAL commands. Then you can edit the gdal_translate command and have total
> control over all the features it supports http://www.gdal.org/gdalwarp.html.
> You may be able to set -dstnodata to some value that does not exist in your
> data, for example "0 0 255" for total blue. Or then you can add alpha
> channel with -dstalpha.
I think this recipe should not be lost. Ho about adding it to the manual, probably
with an "Advanced" flag?
> Unfortunately you can't edit the command and run it as edited directly from
> the georeferencer but you must run it in a separete GDAL command window.
this shouldn't be difficult to add.
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlLU2p8ACgkQ/NedwLUzIr4cTQCbBJCub5CRb1JQqu0XxvdRwwWA
eLkAn3ZcoVw32Ts+C75G3QNKrJPpJfiR
=zQEQ
-----END PGP SIGNATURE-----
