[Qgis-user] TimeManager pluggin error
Carlos Cerdán sig.upagu at gmail.com
Fri Jan 17 07:30:47 PST 2014
 Hi list:
OS: Ubuntu 12.04 (and Windows 7)
QGIS 2.0.1
Language: spanish (es.PE)
I'm trying to use the TimeManager pluggin and i've created a test layer
which has a date field with values as: 2014-01-01, 2014-01-02, etc.
Type data is rigth, but I got this error message:
An error occured while trying to add layer Test to TimeManager.
Test: The attribute specified for use as start time contains invalid data:
PyQt4.QtCore.QDate()
is not one of the supported formats:
['%Y-%m-%d %H:%M:%S', '%Y-%m-%d %H:%M:%S.%f', '%Y-%m-%d %H:%M', '%Y-%m-%d',
'%Y/%m/%d %H:%M:%S']
I've tried with a test layer with three polygons and fields with date
format, as it's suggested in error message, but it doesn't work. I realize
that this is an experimental pluggin but, any suggestion?
Carlos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140117/e069526c/attachment.html>
