[Qgis-user] TimeManager pluggin error
Saulteau Don sault.don at gmail.com
Fri Jan 17 07:52:41 PST 2014
IIRC, you actually have to store the "Date" fields as "String" type
instead then tell the TimeManager what format they are in (ie,
YYYY-MM-DD, etc...).
Donovan
On Fri, Jan 17, 2014 at 8:30 AM, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Hi list:
> OS: Ubuntu 12.04 (and Windows 7)
> QGIS 2.0.1
> Language: spanish (es.PE)
> I'm trying to use the TimeManager pluggin and i've created a test layer
> which has a date field with values as: 2014-01-01, 2014-01-02, etc.
> Type data is rigth, but I got this error message:
> An error occured while trying to add layer Test to TimeManager.
> Test: The attribute specified for use as start time contains invalid data:
> PyQt4.QtCore.QDate()
> is not one of the supported formats:
> ['%Y-%m-%d %H:%M:%S', '%Y-%m-%d %H:%M:%S.%f', '%Y-%m-%d %H:%M', '%Y-%m-%d',
> '%Y/%m/%d %H:%M:%S']
> I've tried with a test layer with three polygons and fields with date
> format, as it's suggested in error message, but it doesn't work. I realize
> that this is an experimental pluggin but, any suggestion?
> Carlos
> Qgis-user mailing list
