[Qgis-user] TimeManager pluggin error
Carlos Cerdán sig.upagu at gmail.com
Fri Jan 17 08:01:27 PST 2014
It works!!! Thank you very much Donovan
Regards from Perú
Carlos
2014/1/17 Saulteau Don <sault.don at gmail.com>
> IIRC, you actually have to store the "Date" fields as "String" type
> instead then tell the TimeManager what format they are in (ie,
> YYYY-MM-DD, etc...).
> Donovan
> On Fri, Jan 17, 2014 at 8:30 AM, Carlos Cerdán <sig.upagu at gmail.com>
> wrote:
> > Hi list:
> > OS: Ubuntu 12.04 (and Windows 7)
> > QGIS 2.0.1
> > Language: spanish (es.PE)
> > I'm trying to use the TimeManager pluggin and i've created a test layer
> > which has a date field with values as: 2014-01-01, 2014-01-02, etc.
> > Type data is rigth, but I got this error message:
> > An error occured while trying to add layer Test to TimeManager.
> > Test: The attribute specified for use as start time contains invalid
> data:
> > PyQt4.QtCore.QDate()
> > is not one of the supported formats:
> > ['%Y-%m-%d %H:%M:%S', '%Y-%m-%d %H:%M:%S.%f', '%Y-%m-%d %H:%M',
> '%Y-%m-%d',
> > '%Y/%m/%d %H:%M:%S']
> > I've tried with a test layer with three polygons and fields with date
> > format, as it's suggested in error message, but it doesn't work. I
> realize
> > that this is an experimental pluggin but, any suggestion?
> > Carlos
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140117/54cffa4f/attachment.html>
