[Qgis-user] Missing data if importing OSM-Data
Andre Joost andre+joost at nurfuerspam.de
Fri Jan 17 12:18:59 PST 2014
Am 17.01.2014 16:25, schrieb Andre Joost:
> Apart from that, I doubt whether relations are imported the same way as
> osm2pgsql converts them to polygons or ways.
Using QGIS 2.0, you could as well add preloaded OSM data with Layer ->
Add Vector layer.
This will also import Multipolygon relations. And you can select
additional tags you want by editing the osmconf.ini file in the share
folder.
HTH,
André Joost
