[Qgis-user] configuración otb y grass
Rafael Torres rafael.torres at orosur.ca
Wed Jan 22 03:39:28 PST 2014
Muchas gracias Don,
Cambié los nombres de las carpetas para que no tengan ese carácter "ó" y parece que funciona ahora.
Sds
Rafael
-----Mensaje original-----
De: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] En nombre de Saulteau Don
Enviado el: lunes, 20 de enero de 2014 11:53 a.m.
Para: qgis-user
Asunto: Re: [Qgis-user] configuración otb y grass
I think \xf3 is the ascii code for ó as seen at http://daleswanson.org/ascii.htm
Maybe the algorithm is having trouble interpreting that character if it's in any of the file names or the path to those files.
Worst case, you would have to remove that from all your filenames, but maybe it can be fixed by adjusting the operating systems default encoding that supports that character?
Unless someone knows that this limitation is part of python or QGIS?
Donovan
On Mon, Jan 20, 2014 at 3:52 AM, Rafael Torres <rafael.torres at orosur.ca> wrote:
> Hola,
> When I run algorithms of otb and grass, it gives me the following error:
> "Traceback (most recent call last):
> File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\GeoAlgorithm.py
> line 150, in execute
> self.processAlgorithm(progress)
> File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\otb\OTBAlgorithm.py"
> line 199, in processAlgorithm
> OTBUtils.executeOtb(commands, progress)
> File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\otb\OTBUtils.py",
> line 117, in executeOtb
> proc = subprocess.Popen(fused_command, shell=True,
> stdout=subprocess.PIPE,
> stdin=subprocess.PIPE,stderr=subprocess.STDOUT,
> universal_newlines=True).stdout
> File "C:\OSGeo4W\apps\Python27\lib\subprocess.py", line 711, in
> __init__
> errread, errwrite)
> File "C:\OSGeo4W\apps\Python27\lib\subprocess.py", line 922, in
> _execute_child
> args = '{} /c "{}"'.format (comspec, args)
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xf3' in
> position
> 86: ordinal not in range(128)"
> File
> File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\grass\GrassAlgorithm
> .py",
> line 356, in processAlgorithm
> self.consoleOutput = GrassUtils.executeGrass(commands, progress,
> outputCommands);
> File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\grass\GrassUtils.py"
> line 246, in executeGrass
> command = GrassUtils.prepareGrassExecution(commands)
> File
> line 225, in prepareGrassExecution
> GrassUtils.createGrassScript(commands)
> File
> line 151, in createGrassScript
> output.write(command + "\n")
> position
> 51: ordinal not in range(128)
> Thanks
> Qgis-user mailing list
