[Qgis-user] Unchecked layers and groups in qgis-web-client
Gunnar Oehmichen
oehm8895 at uni-landau.de
Sat Jan 25 07:32:55 PST 2014
Hi there,
were using QGIS, QGIS-Mapserver (Version: 2.0.1-2+precise1), Apache2 and
the qgis-web-client.
The project within the web-client can be found here:
http://biomass.uni-landau.de/qgiswebclient.html?map=../projects/f-w-vr.qgs
We would like the project tree menu to be expanded with all layers
except one and the wms base-layers to be unchecked as you can see in the
screenshot from the corresponding .qgs file.
https://www.box.com/shared/aecep37qj3bqn2ylcr2e
If the information helps, layers to be unchecked are imported from
postgis. While QGIS-Desktop was still loading the data from the db i
also recognized layers not beeing unchecked, they only resumed to beeing
unchecked after all layers were finally loaded.
Is there a way to achieve this?
