[Qgis-user] Print composer 'loses' maps
Hanlie Pretorius hanlie.pretorius at gmail.com
Mon Jan 27 06:14:41 PST 2014
Hi Carlos,
Thanks for the reply.
I checked that property and it said 'cache'. Neither 'cache' nor
'render' plus 'Update preview' brings the map back.
Cheers
Hanlie
> Date: Mon, 27 Jan 2014 08:08:56 -0500
> From: Carlos Cerd?n <sig.upagu at gmail.com>
> Hi Hanlie:
> Perhaps it's just the automatic (and not always desired) change to
> "rectangle" view. If so, you have a rectangle where it's says "The map will
> be printed here" (or something similar - in Spanish it says "el mapa se
> imprimir? aqu?"). In composer select the map and in "principal properties",
> change from rectangle to "cache" or "drawing? ("representar" in Spanish).
> Is it this issue?.
> Regards
> Carlos
