[Qgis-user] Print composer 'loses' maps
Carlos Cerdán
sig.upagu at gmail.com
Mon Jan 27 05:08:56 PST 2014
Hi Hanlie:
Perhaps it's just the automatic (and not always desired) change to
"rectangle" view. If so, you have a rectangle where it's says "The map will
be printed here" (or something similar - in Spanish it says "el mapa se
imprimirá aquí"). In composer select the map and in "principal properties",
change from rectangle to "cache" or "drawing? ("representar" in Spanish).
Is it this issue?.
Regards
Carlos
2014-01-27 Hanlie Pretorius <hanlie.pretorius at gmail.com>
> Hi,
> I'm working with QGIS 2.0.1 in Windows 7.
> I created a QGIS project and three print composers with different
> views and layers switched on in each. I saved the composers using the
> 'Save project' icon in the Print Composer window.
> Subsequently I edited the QGIS project, added some layers and removed
> some others.
> Now when I open the print composers, none of them contain any maps
> anymore. The legends etc. are still there, but they have no map image.
> What am I doing wrong? How can I save a print layout from session to
> session?
> Thanks
> Hanlie
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140127/f25e3285/attachment.html>
