[Qgis-user] WFS caching behaviour
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Jan 28 00:12:15 PST 2014
Hi Jukka,
  You do seem to like Fiddler!
I was using my web-server logs, however Fiddler is confirming that the WFS
isn't making new requests when I zoom in/our except when I'm at distance
zoom's (it should do it at all zooms).
So bug report it is.
Cheers,
Jonathan
On 27 January 2014 18:05, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi> wrote:
> Jonathan Moules <jonathanmoules at ...> writes:
> > Hi List,Before I report this one as a bug, I figured I should check.
> > What's the desired behaviour of the WFS client in QGIS in respect to
> caching results versus making new requests.
> > Example:
> > WFS server only returns 500 results for any given request. There are
> 51639
> features in the layer.
> > - If I load the layer using the "Cached" checkbox as ticked, then QGIS
> only loads 500 features. Fine.
> > - If I then add the layer again, but with "cached" unticked, then QGIS
> only loads 500 features - but they're 500 different features. Fine.
> > Except in both cases when I zoom in/out, the features don't change; QGIS
> doesn't make new requests. I thought it was supposed to, at least with the
> uncached version? Both appear to behaving the exact same way to me.
> > Am I doing something wrong?
> Hi,
> Made a trial with v. 2.0.1 and checked with Fiddler2 proxy what happens (I
> recommend).
> - With caching a plain GetFeature is sent and you will get the 500 first
> records.
> - Without caching QGIS adds a BBOX filter and applies the extents of the
> current map view. You will get the first 500 records within the box.
> - After zooming/panning a new request with BBOX filter gets fired.
> I can't say why QGIS does not send new features for you. But you a the one
> who should absolutely install Fiddler or some other logging proxy and you
> can do loads of wonderful bug reports in the future.
> -Jukka Rahkonen-
> > Thanks,Jonathan
> > This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> > Qgis-user mailing list
> > Qgis-user at ...
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140128/4949d682/attachment.html>
