[Qgis-user] WFS caching behaviour
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Jan 27 10:05:55 PST 2014
Jonathan Moules <jonathanmoules at ...> writes:
> Hi List,Before I report this one as a bug, I figured I should check.
> What's the desired behaviour of the WFS client in QGIS in respect to
caching results versus making new requests.
> Example:
> WFS server only returns 500 results for any given request. There are 51639
features in the layer.
> - If I load the layer using the "Cached" checkbox as ticked, then QGIS
only loads 500 features. Fine.
> - If I then add the layer again, but with "cached" unticked, then QGIS
only loads 500 features - but they're 500 different features. Fine.
> Except in both cases when I zoom in/out, the features don't change; QGIS
doesn't make new requests. I thought it was supposed to, at least with the
uncached version? Both appear to behaving the exact same way to me.
> Am I doing something wrong?
Made a trial with v. 2.0.1 and checked with Fiddler2 proxy what happens (I
recommend).
- With caching a plain GetFeature is sent and you will get the 500 first
records.
- Without caching QGIS adds a BBOX filter and applies the extents of the
current map view. You will get the first 500 records within the box.
- After zooming/panning a new request with BBOX filter gets fired.
I can't say why QGIS does not send new features for you. But you a the one
who should absolutely install Fiddler or some other logging proxy and you
can do loads of wonderful bug reports in the future.
-Jukka Rahkonen-
> Thanks,Jonathan
> This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
> Qgis-user at ...
