[Qgis-user] Print Composer - Rotation of Shapefiles with transparency
Mike Flannigan mikeflan at att.net
Tue Jan 28 15:26:06 PST 2014
I'd try this out for you, but I can't find the rotate capability
in "Project" - "New Print Composer".  Across from Rotation I have
Portrait and Landscape, but that is all.
Mike
Any chance you could answer this question below
that I posted 2 weeks ago?
Interestingly, I don't seem to have OSM plugin on
my version 2.0.1.  I don't see it under Installed
and I don't see it under Get more, though there is
an OSMEditorRemoteControl in the Get more tab.
How do I get it on ver 2.0.1 QGIS - Win64 version?
To start the Plugin Manager go to "Plugins" -
"Manage and Install Plugins".
Mike
On 1/28/2014 4:06 AM, qgis-user-request at lists.osgeo.org wrote:
> Message: 8
> Date: Tue, 28 Jan 2014 10:25:41 +0100
> From: N St<tuthalija at gmail.com>
> To:qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Print Composer - Rotation of Shapefiles with
> 	transparency
> Message-ID:
> 	<CAGm1btUhe9-W2kf1Dt57Y5LyLuuZRK48cvK0ws3nEEeHeXUZ+w at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi List,
> I try to rotate a map in the print composer and I have an awkward problem.
> I wanted to check if I am alone in this case, or if it's a bug.
> I work under Windows 7 64 Pro - QGIS is 2.0.1.
> When I rotate a map in the print composer, shapefiles are cut at a right
> angle (according to the north) if the transparency is not set at 0. If the
> transparency is set at zero, no problems. When I rotate the map from 180
> degrees it works fine too, but anything else doesn't. Output is the same if
> it exported in .jpg, .pdf, ...
> Enclosed the output with the print composer and a rotation of 330 degrees
> and a screenshot of the print composer (the map is cached). The
> transparency of the green layer is set at 5%, 0% for the red. You can see
> how the green layer is cut ...
> Screenshot:http://imgur.com/ZtCdfwY
> Print output:http://imgur.com/3iBFwXD
> This problem doesn't appear for raster with/without transparency.
> I already tried to modify every option I knew, but it doesn't work.
>   Any hints?
> Thanks a lot
> Nebi
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140128/3e5e6a36/attachment.html>
