[Qgis-user] CRS and scales
Alexandre Neto senhor.neto at gmail.com
Wed Jan 29 04:56:39 PST 2014
Hello Pat,
The data is probably in different CRSs. Setting the CRS of the layers won't
change the data itself, it only asks QGIS to try represent the data in that
specific CRS. If you set it wrong (or if QGIS guess it wrong) the layers
won't be represented at the correct coordinates.
You must find out the the correct CRS of each layer (ask where you get your
data) and set it using Right-click layer > Set Layer CRS.
Now... the minus value of the scale is quite odd, can you send a sample of
your data?
Best regards,
Alexandre Neto
On Wed, Jan 29, 2014 at 11:31 AM, Pat Brown <mistyhaven at gmail.com> wrote:
> I have two layers (Shp files) which, when I open them, appear to be in two
> different projections (I am using QGIS 2.0.1 on Win 7 prof). I have
> followed all the instructions to get them to to project the same but they
> still will not overlay each other. When I check the CRS for each layer they
> are the same. I have set the project CRS to be the same. The only
> difference that I can find is that the scales of the two layers are totally
> different. The one scale is 1:7397941 and the other is 1:-2147483648 (the
> minus sign is correct). This is just too weird. Can anyone explain what is
> happening (so I can rectify it myself in future) and how to go about
> correcting this to get the right display?
> Thanks,
> Paddy
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140129/114376e0/attachment.html>
