[Qgis-user] "Re:Re: Print Composer - Rotation of Shapefiles with transparency"
N St tuthalija at gmail.com
Wed Jan 29 13:11:39 PST 2014
To make a rotation in the Print Composer
- Add a map
- In the "Item Properties" you have, a the top, in the dialogue "Main
properties" a field rotation that you can set: (from 0 to 360)
Here you find all the information:
http://www.qgis.org/en/docs/user_manual/print_composer/print_composer.html#adding-a-current-qg-map-canvas-to-the-print-composer
@Mike
For your Problem : "QGIS 2.0 integrates OSM as a core functionality, which
makes the plugin obsolete": don´t search the plugin you won´t find it.
But you´re right, there are some problems with 64 bits :
http://wiki.openstreetmap.org/wiki/QGIS_OSM_Plugin
(I never tried it ...)
Nebi
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140129/eb3e0745/attachment.html>
