[Qgis-user] [Qgis-user} Editing the attribute table
Bernhard Ströbl bernhard.stroebl at jena.de
Fri Jan 31 00:29:11 PST 2014
Hi Brett,
if all you want to achieve is another name in the attribute dialog and
the attribute table you could set an alias for the field in question, no
need to _change_ the field name in the data source.
this is at least true for QGIS 2.0.1
Am 31.01.2014 09:08, schrieb Andreas Neumann:
> Hi Brett,
> Unfortunately not, currently (also not in version 2.0). You have to
> create a new field with the new name, use the field calculator to
> transfer the value and then delete the old column.
the field calulator can also create the field for you, so no need to
create it beforehand
Bernhard
> The side effect is
> that the order of the columns will be changed. I guess one could write
> an attribute renamer plugin to do that if you have to do it often.
> I don't know how important the order of the columns is to you. In QGIS
> 2.0 one can re-order the columns, at least in the attribute form if you
> use the drag and drop designer.
> Sorry that I don't have a better solution,
> Andreas
> Am 31.01.2014 07:00, schrieb Brett Adams:
>> Hi Folks,
>> Can I change/edit the name of attributes within the attribute table for SHP
>> files.  I don't want to edit the values in the table, just the name.
>> Running 1.8 Lisboa
>> Brett  Adams
>> Spinifex Geophysics
>> 0438 861 974
__________ Information from ESET Mail Security, version of virus signature database 9360 (20140130) __________
The message was checked by ESET Mail Security.
http://www.eset.com
