[Qgis-user] Citrix and QGIS
McDonaldR McDonaldR at angus.gov.uk
Fri Jan 31 05:31:17 PST 2014
Hi Steve
We've just installed QGIS in Citrix and had to complete the base install and then configure QGIS with connections to databases and web services.  Then install any additional plugins that users might need (gazetteer search).  Then the Citrix server is set to read-only to save the base image.  I guess you could build a package for QGIS with everything configured and then install that in the Citrix environment but you only need to do one install so probably not worth the effort of building a bespoke package.
The system is set up to allow individual users their own .qgis2 folder which they have read/write access to.  This mean that technically they are able to install plugins as they are saved in the .qgis2\python\plugins folder.  Not sure about restricting access to updates as our install needs internet access for web services and the plugin manager must look for updates automatically.
Our server spec is pretty beefy with heaps of RAM and fast processors.  As it is single threaded (for now) the fastest processor will help and probably a minimum of 2GB RAM.  We installed the 64bit version to get around limitations when printing.
The Citrix bit we needed the most work on was allowing access to the .qgis2 folder to save configurations per user and sorting internet access.  Compared to configuring ArcGIS, QGIS was a breeze as it just worked for the most part.
Cheers
Ross
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Steven Campbell
Sent: 31 January 2014 12:39
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Citrix and QGIS
Hi
I was wondering if anyone had successfully deployed QGIS via a Citrix (Thin Client) environment and could answer the following questions:
1)     Is it possible to compile an installer package that not only installs qgis, but installs the required plugins too?
2)     Can you get QGIS to install so it doesn't look for updates to either software or plugins?
3)     Is there a minimum spec/requirement for an install on a Citrix environment for QGIS to function correctly?
Thanks in advance
Steve
Steve Campbell | GIS Manager
Corporate Strategy and Communications
Borough of Poole | Civic Centre | Poole BH15 2RU
Tel: 01202 633 362
Email: s.campbell at poole.gov.uk<mailto:s.campbell at poole.gov.uk>
Website:www.boroughofpoole.com<http://www.boroughofpoole.com/>
Think Green! Please Recycle
DISCLAIMER: This email and any files transmitted with it may be confidential, legally privileged and protected in law and are intended solely for the use of the individual to whom it is addressed. The copyright in all documentation is the property of the Borough of Poole and this email and any documentation must not be copied or used other than as strictly necessary for the purpose of this email, without prior written consent which may be subject to conditions. Any view or opinions presented are solely those of the author and do not necessarily represent those of the Borough of Poole. The Borough of Poole reserves the right to inspect incoming and outgoing emails. If you have received this email in error please contact the sender by return and confirm that its contents have been destroyed. Telephone enquiries should be directed to the Borough switchboard on 01202 633633.'
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons.  Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140131/8d44fc5a/attachment.html>
