[Qgis-user] Converting Vector to Raster; or Digitisation
HPETER784 at aol.com
Fri Jan 31 06:56:42 PST 2014
I am a new user of qgis 2.0.1 Dufour.
I have a shapefile of contours sourced from the British Ordnance Survey via
Stanfords in vector format. I need the contours to be in Raster form, so
that I can map the altitudes coloured in as usual, say green for low
levels to brown for higher altitudes. Also I want to plot the slopes, which
can only be calculated in Raster format.
I don't think using the rasterising facility will work, since the shapefile
only recognises the polylines in two dimensions and has no knowledge of
the altitudes.
I am wondering if I can digitize into a raster shapefile from the vector
map on the computer screen. But I cannot see how I can do this exactly.
I suppose this is a common task, but how to do it? Thanks for any advice.
Peter Hutchinson,
MILVERTON,
Taunton
01823 400 272
hpeter784 at aol.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140131/d4a2e451/attachment.html>
