[Qgis-user] Converting Vector to Raster; or Digitisation
Alexandre Neto senhor.neto at gmail.com
Fri Jan 31 07:40:38 PST 2014
Hello Peter,
Is indeed a common task. To get a surface from a vector contours lines (or
from a set of points) you will need to use the Interpolation plugin.
Best regards,
Alexandre Neto
On Fri, Jan 31, 2014 at 2:56 PM, <HPETER784 at aol.com> wrote:
>  I am a new user of qgis 2.0.1 Dufour.
> I have a shapefile of contours sourced from the British Ordnance Survey
> via Stanfords in vector format.  I need the contours to be in Raster form,
> so that I can map the altitudes coloured in as  usual, say green for low
> levels to brown for higher altitudes.  Also I want to plot the slopes,
> which can only be calculated in Raster format.
> I don't think using the rasterising facility will work, since the
> shapefile only recognises the polylines in two dimensions and has no
> knowledge of the altitudes.
> I am wondering if I can digitize into a raster shapefile from the vector
> map on the computer screen.  But I cannot see how I can do this exactly.
> I suppose this is a common task, but how to do it?  Thanks for any
> advice.
> Peter Hutchinson,
> MILVERTON,
> Taunton
> 01823 400 272
> hpeter784 at aol.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140131/c5d8e6e0/attachment.html>
