[Qgis-user] Street Map
kimaidou kimaidou at gmail.com
Fri Jan 31 13:47:11 PST 2014
Hi
You could also download OSM data in Shapfile format, e.g. from Geofabrik
website :
http://www.geofabrik.de/data/shapefiles.html
Load the layers in QGIS, then style them, or get some available in some
shared repositories, e.g.
https://github.com/3liz/osm-in-qgis
You can then tune the styles (and contribute back if you want)
Cheers
Michael
2014-01-31 Gabriele Baccini <gbaccini at yahoo.it>:
> Thanks for your answer.
> Have you try this progr?
> i see
> Gabry
>   Il Giovedì 30 Gennaio 2014 17:42, Etienne Tourigny <
> etourigny.dev at gmail.com> ha scritto:
>  It might be easier to install the software on your computer/server and
> required databases, modified to your needs?
> http://maposmatic.org/about/
> On Thu, Jan 30, 2014 at 1:23 PM, Gabriele Baccini <gbaccini at yahoo.it>wrote:
> I need to create a Street Map like the jpg attached
> I don't know how to create a list of the roads.
> there is a website (http://maposmatic.org/) using openstreetmap and makes these
> maps, but I have to use Qgis because I have to edit root maps.
> Have yuo got any idea?
> Is there a plugin that does it?
> thanks
> Gabry
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140131/96afb012/attachment.html>
