[Qgis-user] convert point data to color gradient
    Stephen Leake
    stephen_leake at stephe-leake.org
    Tue Jun 10 03:05:20 PDT 2014
I'm using Qgis 2.2.0-Valmiera 64 bits, on MS Windows 7.
I'm just getting started with Qgis, and GIS in general.
I'm trying to create a map similar to
http://nadp.sws.uiuc.edu/maplib/pdf/mdn/hg_Conc_2011.pdf, with updated
data, and for Kansas only.
I have data in an MS Excel spreadsheet; I can import that to QGIS via a
.csv intermediate.
Now I need to convert that point data into a color gradient.
I found the algorithm Processing | Toolbox | Models | Example | Contour
lines from points ; that seems like a good first step.
However, when I try to run it, it produces an error message. I can't
read the entire error message, because the window closes.
More precisely:
load the project with the data
double click on Processing | Toolbox | Models | Example | Contour
lines from points
Keep the default selections; in particular, "open output file ..." is
checked.
click Run
An error dialog pops up: title "Problem loading output layers", text
saying "file ... cannot be opened ...".
I can see part of the error message in the "Contour lines from points"
window, but I can't scroll to see the rest.
When I close the error window, the "Contour lines from points" window
also closes.
If I uncheck "open output file ...", the "Contour lines from points"
window closes immediately.
1) Is there a way to keep the algorithm window open after failure, so I
can scroll to see the entire error message?
2) This appears to be running a command line executable in a sub-shell;
how do I find out what that executable is, so I can try to run it
directly?
3) Once I get the contour map, what algorithm will convert it to a color
gradient?
4) Is there a better way?
Thanks,
-- Stephe
