[Qgis-user] convert point data to color gradient
Stephen Leake stephen_leake at stephe-leake.org
Tue Jun 10 03:22:33 PDT 2014
Stephen Leake <stephen_leake at stephe-leake.org> writes:
> double click on Processing | Toolbox | Models | Example | Contour
> lines from points
> 2) This appears to be running a command line executable in a sub-shell;
> how do I find out what that executable is, so I can try to run it
> directly?
Found this; right click on algorithm, select "save as python script".
That says it is running three algorithms: saga:shapestogrid,
saga:closegaps, saga:contourlinesfromgrid
saga is in c:/Program Files (x86)/QGIS Valmiera/apps/saga. I'll play
with that.
-- Stephe
