[Qgis-user] TAB file export
Ross McDonald ross at mixedbredie.net
Tue Jun 10 23:01:41 PDT 2014
Hi Brett
Can you convert the shapefile to mapinfo (TAB or MIF/MID?) on the
command line with ogr2ogr?
Can you upgrade to QGIS 2.2 or wait a couple of weeks for 2.4?  It uses
a new version of GDAL/OGR.
Have you checked http://www.gdal.org/drv_mitab.html for possible error
sources?  And see
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Unable-to-create-MApInfo-tab-File-td5095559.html
for the same error but no solution :-(
Ross
On 11/06/14 06:23, Brett Adams wrote:
> Hi folks,
> Trying to save a SHP file as a TAB file.
> SHP file contains attributed points.
> I keep getting  an error
> Export to vector file failed.
> Error: Feature write errors:
> Feature creation error (OGR error: Failed writing geometry for feature
> id 1 in
> Attempted procedure is
> Layer >>Save As >>   Format = Mapinfo
> I have "Encoding = System"
> Running 1.8 Lisboa on W7-64
> What am I doing wrong????
> *Brett Adams*
> *Spinifex Geophysics*
> *0438 861 974*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140611/b458907c/attachment.html>
