[Qgis-user] TAB file export
Werner Macho werner.macho at gmail.com
Tue Jun 10 23:41:56 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi!
The Defaults in 1.8 were not very good ..
It should be possible to do the export this way but you have to use
the OGR creation options for Data source and Layer.
As far as I remember the SPATIAL_INDEX_MODE in Layer Options must be set.
As this uses GDAL/OGR function its best to look at the GDAL Webpage.
Depending on the version of GDAL you have there might be other issues
as well.
After all I can only support Ross - it's best to update to QGIS2.2
regards
Werner
On 06/11/2014 07:01 AM, Ross McDonald wrote:
> Hi Brett
> Can you convert the shapefile to mapinfo (TAB or MIF/MID?) on the
> command line with ogr2ogr?
> Can you upgrade to QGIS 2.2 or wait a couple of weeks for 2.4?  It
> uses a new version of GDAL/OGR.
> Have you checked http://www.gdal.org/drv_mitab.html for possible
> error sources?  And see
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Unable-to-create-MApInfo-tab-File-td5095559.html
for the same error but no solution :-(
> Ross
> On 11/06/14 06:23, Brett Adams wrote:
>> Hi folks,
>> Trying to save a SHP file as a TAB file.
>> SHP file contains attributed points.
>> I keep getting  an error
>> Export to vector file failed.
>> Error: Feature write errors:
>> Feature creation error (OGR error: Failed writing geometry for
>> feature id 1 in
>> Attempted procedure is
>> Layer >>Save As >>   Format = Mapinfo
>> I have "Encoding = System"
>> Running 1.8 Lisboa on W7-64
>> What am I doing wrong????
>> *Brett Adams*
>> *Spinifex Geophysics*
>> *0438 861 974*
>> _______________________________________________ Qgis-user mailing
>> list Qgis-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iEYEARECAAYFAlOX+jQACgkQDAH1YiCxBgk4sgCfY+uO7dwcIHUYtI8n2WWtfh3K
wLQAn1qaU5r602IZUNWE/MBQE19W1hjd
=114P
-----END PGP SIGNATURE-----
