[Qgis-user] TAB file export
Brett Adams badams at spinifexgeophysics.com.au
Tue Jun 10 23:43:41 PDT 2014
Thanks Ross.
Downloaded ogr2ogr.  Program ran, created TAB files but they were empty.
Does that mean there is a problem with the SHP file?
Read through the other web sites couldn't see anything obvious, which it
would need to be for me to figure it out.
No matter,  might hold out for 2.4.  Should update at some stage I guess.
Thanks Again
brett
From: Ross McDonald [mailto:ross at mixedbredie.net]
Sent: Wednesday, 11 June 2014 2:02 PM
To: Brett Adams; 'qgis-user'
Subject: Re: [Qgis-user] TAB file export
Hi Brett
Can you convert the shapefile to mapinfo (TAB or MIF/MID?) on the command
line with ogr2ogr?
Can you upgrade to QGIS 2.2 or wait a couple of weeks for 2.4?  It uses a
new version of GDAL/OGR.
Have you checked http://www.gdal.org/drv_mitab.html for possible error
sources?  And see
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Unable-to-create-MApInfo-tab-Fi
le-td5095559.html for the same error but no solution :-(
Ross
On 11/06/14 06:23, Brett Adams wrote:
Hi folks,
Trying to save a SHP file as a TAB file.
SHP file contains attributed points.
I keep getting  an error
Export to vector file failed.
Error: Feature write errors:
Feature creation error (OGR error: Failed writing geometry for feature id 1
in
Attempted procedure is
Layer >>Save As >>   Format = Mapinfo
I have "Encoding = System"
Running 1.8 Lisboa on W7-64
What am I doing wrong????
Brett  Adams
Spinifex Geophysics
0438 861 974
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140611/52dda165/attachment.html>
