[Qgis-user] TAB file export
Zoltan Szecsei zoltans at geograph.co.za
Wed Jun 11 00:04:37 PDT 2014
Hi Brett,
I do this sort of thing regularly (shapefiles -> MID/MIF, though) so I'm
surprised at the issues you are having.
Please post the ogr2ogr command-line you are using, and, if ok, maybe a
sample of the shapefile.
Have you tried saving as another format? That may tell you if your
shapefile is the problem.
Regards,
Zoltan
On 2014/06/11 08:43, Brett Adams wrote:
> Thanks Ross.
> Downloaded ogr2ogr.  Program ran, created TAB files but they were
> empty.  Does that mean there is a problem with the SHP file?
> Read through the other web sites couldn't see anything obvious, which
> it would need to be for me to figure it out.
> No matter, might hold out for 2.4.  Should update at some stage I guess.
> Thanks Again
> brett
> *From:*Ross McDonald [mailto:ross at mixedbredie.net]
> *Sent:* Wednesday, 11 June 2014 2:02 PM
> *To:* Brett Adams; 'qgis-user'
> *Subject:* Re: [Qgis-user] TAB file export
> Hi Brett
> Can you convert the shapefile to mapinfo (TAB or MIF/MID?) on the
> command line with ogr2ogr?
> Can you upgrade to QGIS 2.2 or wait a couple of weeks for 2.4?  It
> uses a new version of GDAL/OGR.
> Have you checked http://www.gdal.org/drv_mitab.html for possible error
> sources?  And see
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Unable-to-create-MApInfo-tab-File-td5095559.html
> for the same error but no solution :-(
> Ross
> On 11/06/14 06:23, Brett Adams wrote:
>     Hi folks,
>     Trying to save a SHP file as a TAB file.
>     SHP file contains attributed points.
>     I keep getting  an error
>     Export to vector file failed.
>     Error: Feature write errors:
>     Feature creation error (OGR error: Failed writing geometry for
>     feature id 1 in
>     Attempted procedure is
>     Layer >>Save As >>   Format = Mapinfo
>     I have "Encoding = System"
>     Running 1.8 Lisboa on W7-64
>     What am I doing wrong????
>     *Brett Adams*
>     *Spinifex Geophysics*
>     *0438 861 974*
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140611/14b1aaaf/attachment.html>
