[Qgis-user] Error with QGIS Server on Debian wheezy
Zedler, Jörg (regio iT) Joerg.Zedler at regioit.de
Wed Jun 11 00:48:31 PDT 2014
I have found an explanation for my problem:
Although in my project the path to Shape-File is stored relative, QGIS Server interpreted the path as an absolute path.
Example out of the project file:
<datasource>./TestShape.shp</datasource>
Therefore the shape file is not found.
With an symbolic link in root-directory, everything works.
Is this problem known?
Is there any better workaround?
Thanks,
J. Zedler
Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Zedler, Jörg (regio iT)
Gesendet: Donnerstag, 5. Juni 2014 21:07
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Error with QGIS Server on Debian wheezy
I need some help, running QGIS Server 2.2.0 on Debian wheezy.
Using QGIS-Projects with Datasource Postgres works fine.
Using QGIS-Projects with Datasource Shape-File didn't work.
The same Project on Windows (also QGIS Server 2.2.0) works.
GetCapabilities-Request gives all but no info for Shape-Layers
Output on stderr: ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'
GetMap-Request crashes with Segmentation fault
The Debian-Server is installed without X-Server Packages.
Is there any idea, what's going wrong?
Regards
J. Zedler
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140611/1812b396/attachment.html>
