[Qgis-user] Error with QGIS Server on Debian wheezy
Andrea Peri aperi2007 at gmail.com
Wed Jun 11 04:14:18 PDT 2014
I confirm this situation with spatialite.
To partially resolve we modify manually the paths when transfer on
qgis.server.
A search and replace.
 Il 11/giu/2014 09:48 "Zedler, Jörg (regio iT)" <Joerg.Zedler at regioit.de>
ha scritto:
>  Hi,
> I have found an explanation for my problem:
> Although in my project the path to Shape-File is stored relative, QGIS
> Server interpreted the path as an absolute path.
> Example out of the project file:
> <datasource>./TestShape.shp</datasource>
> Therefore the shape file is not found.
> With an symbolic link in root-directory, everything works.
> Is this problem known?
> Is there any better workaround?
> Thanks,
> J. Zedler
> *Von:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *Im Auftrag von *Zedler, Jörg (regio
> iT)
> *Gesendet:* Donnerstag, 5. Juni 2014 21:07
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Error with QGIS Server on Debian wheezy
> Hi,
> I need some help, running QGIS Server 2.2.0 on Debian wheezy.
> Using QGIS-Projects with Datasource Postgres works fine.
> Using QGIS-Projects with Datasource Shape-File didn’t work.
> The same Project on Windows (also QGIS Server 2.2.0) works.
> GetCapabilities-Request gives all but no info for Shape-Layers
> Output on stderr: ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'
> GetMap-Request crashes with Segmentation fault
> The Debian-Server is installed without X-Server Packages.
> Is there any idea, what’s going wrong?
> Regards
> J. Zedler
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140611/55c41d39/attachment.html>
