[Qgis-user] Linux build
Volker Fröhlich volker27 at gmx.at
Wed Jun 11 14:15:51 PDT 2014
Am 2014-06-11 22:41, schrieb David J. Bakeman:
> I am running qgis on a Fedora core 18 laptop. I run both the packcaged
> qgis 1.8 and I build the development version.  Recently I wanted to use
> spatialite version 4.1.1 instead of the 3.1 version packaged with
> Fedora.  I successfully built both sqlite 3.8 and Spatialite 4.1.1.  I
> built static libraries to avoid accidentally picking up the system
> shared libraries. When I tried to configure qgis to use the new
> libraries by changing the paths
> SPATIALITE_INCLUDE_DIR/SPATIALITE_LIBRARY/SQLITE3_INCLUDE_DIR/SQLITE3_LIBRARY
> but this didn't work.  The only way I was able to get it to work was to
> modify the FindSPATIALITE.cmake script to the skip the library check and
> to add -DSPATIALITE_VERSION_GE_4_0_0 to the CMAKE_CXX_FLAGS.
> My question is should I have been able to just adjust the
> spatialite/sqlite variables or is the way I did it the only way?
> Qgis-user mailing list
Fedora 18 is out of maintenance! :)
Fedora 20 has 2.2. Will that do?
Volker
