[Qgis-user] Linux build
Volker Fröhlich
volker27 at gmx.at
Wed Jun 11 14:20:45 PDT 2014
Am 2014-06-11 23:15, schrieb Volker Fröhlich:
> Am 2014-06-11 22:41, schrieb David J. Bakeman:
>> I am running qgis on a Fedora core 18 laptop. I run both the packcaged
>> qgis 1.8 and I build the development version. Recently I wanted to use
>> spatialite version 4.1.1 instead of the 3.1 version packaged with
>> Fedora. I successfully built both sqlite 3.8 and Spatialite 4.1.1. I
>> built static libraries to avoid accidentally picking up the system
>> shared libraries. When I tried to configure qgis to use the new
>> libraries by changing the paths
>> SPATIALITE_INCLUDE_DIR/SPATIALITE_LIBRARY/SQLITE3_INCLUDE_DIR/SQLITE3_LIBRARY
>> but this didn't work. The only way I was able to get it to work was to
>> modify the FindSPATIALITE.cmake script to the skip the library check and
>> to add -DSPATIALITE_VERSION_GE_4_0_0 to the CMAKE_CXX_FLAGS.
>> My question is should I have been able to just adjust the
>> spatialite/sqlite variables or is the way I did it the only way?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Fedora 18 is out of maintenance! :)
> Fedora 20 has 2.2. Will that do?
> Volker
Wait, Fedora 20 actually has 2.0. I was afraid to push 2.2 because of
some issues when opening 2.0 projects. However, you can install 2.2 in
Fedora 20: yum --enablerepo=updates-testing install qgis-whatever
Volker
