[Qgis-user] TAB file export
Brett Adams badams at spinifexgeophysics.com.au
Wed Jun 11 18:03:29 PDT 2014
Zoltan,
I'm running the ogr2ogr using ogr2gui.  Is that cheating?  I get in trouble
with command line stuff.
I can export a mid/mif, works perfectly every time.  It's just not what the
client wants.  I've attached a sample SHP file. It was created by importing
a CSV file then exporting as a SHP file.
Donovan,
I ran  : Vector > Geometry Tools > Check Geometry Validity     but came up
with no errors.
Couldn't find the "Topology Checker" plugin.  Is that a version 2 feature?
Thanks your feedback.  I appreciate the effort.
Brett
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saulteau Don
Sent: Thursday, 12 June 2014 3:53 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] TAB file export
>> Ross
>> On 11/06/14 06:23, Brett Adams wrote:
>>     I keep getting  an error
>>     Export to vector file failed.
>>     Error: Feature write errors:
>>     Feature creation error (OGR error: Failed writing geometry for
>>     feature id 1 in
I usually get that error when some of the shapefile features are "invalid".
Did you get a chance to check for validity of the features in the shapefile?
In QGIS you can use the "Topology Checker" plugin.
Or Vector > Geometry Tools > Check Geometry Validity.
Donovan
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/f75d88b2/attachment.bin>
