[Qgis-user] Error with QGIS Server on Debian wheezy
Andrea Peri aperi2007 at gmail.com
Thu Jun 12 00:41:28 PDT 2014
My bad
I do a rapid test and on windows it seem to work.
I surely had some troubles when move a qgis project from a windows
machine to a linux server.
The relative paths seem don't work correctly.
This was experienced in the qgis 2.0 version.
I don't explore more and choose the rapid and easy solution to change
manually the
paths in the file (with a script obviously).
>From that time I do no more tests.
I see now it seem to work, but I donnot any test moving the project on
server side.
So perhaps the problem is on Linux..
I do some other test.
Regards.
2014-06-12 9:20 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> Hi
> The server normally detects the relative path and expands it to an absolute
> one internally.
> I just tested a project with relative pathes containing a shape and a
> spatialite layer and it worked fine here (tested with QGIS 2.2 / current
> master / Enterprise worked in all cases).
> Regards,
> Marco
> On 11.06.2014 09:48, Zedler, Jörg (regio iT) wrote:
> Hi,
> I have found an explanation for my problem:
> Although in my project the path to Shape-File is stored relative, QGIS
> Server interpreted the path as an absolute path.
> Example out of the project file:
> <datasource>./TestShape.shp</datasource>
> Therefore the shape file is not found.
> With an symbolic link in root-directory, everything works.
> Is this problem known?
> Is there any better workaround?
> Thanks,
> J. Zedler
> Von: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Zedler, Jörg
> (regio iT)
> Gesendet: Donnerstag, 5. Juni 2014 21:07
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Error with QGIS Server on Debian wheezy
> Hi,
> I need some help, running QGIS Server 2.2.0 on Debian wheezy.
> Using QGIS-Projects with Datasource Postgres works fine.
> Using QGIS-Projects with Datasource Shape-File didn’t work.
> The same Project on Windows (also QGIS Server 2.2.0) works.
> GetCapabilities-Request gives all but no info for Shape-Layers
> Output on stderr: ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'
> GetMap-Request crashes with Segmentation fault
> The Debian-Server is installed without X-Server Packages.
> Is there any idea, what’s going wrong?
> Regards
> J. Zedler
> Qgis-user mailing list
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
Andrea Peri
qwerty àèìòù
