[Qgis-user] Issue installing compiled QGIS release_2-2
Hillers Heather Heather.Hillers at erftverband.de
Fri Jun 13 00:41:11 PDT 2014
Hello,
I am having troubles with the results of make install for QGIS branch release_2-2.
I have on Ubuntu Precise a production Qgis 2.2 from Ubuntugis-unstable packages.  I want to test Qgis 2.2 with Oracle support in a second installation on the same machine.
Following the instructions in INSTALL, I compiled 2.2 and ran make install to prefix /usr/local. This Qgis ran, but did not have PYQGIS support.
I got the error below at program load.
When I run from build/output/bin/qgis, the program works without error.  I tried installing to /usr/local/qgisdev, and to $HOME/qgisdev, with the same error result.
The install is also failing to load the grass plugin, which also has no problems in the build dir.
I don't see anything where my production distribution is clobbering.  Any suggestions would be extremely appreciated (including a "hey, but you can get an Ubuntu Precise Qgis 2.2 with Oracle support package from here and you don't really have to compile it" suggestion)
Thanks, Thanks, Thanks,
Heather
PyQGIS konnte nicht geladen werden.
Die Python-Unterstützung wird abgeschaltet.
  File "", line 1, in
  File "/usr/local/share/qgis/python/qgis/__init__.py", line 35, in
    from qgis.core import QgsFeature, QgsGeometry
ImportError: /usr/local/share/qgis/python/qgis/core.so: undefined symbol: _ZN16QgsComposerShape12setSceneRectERK6QRectF
Python-Version:
2.7.3 (default, Feb 27 2014, 20:09:21)
[GCC 4.6.3]
QGIS-Version:
2.2.0-Valmiera 'Valmiera', exported
Python-Pfad:
['/usr/local/share/qgis/python',
u'/pse/edv/hil/.qgis2/python',
u'/pse/edv/hil/.qgis2/python/plugins',
'/usr/local/share/qgis/python/plugins',
'/usr/local/lib/python2.7/dist-packages/Trac-1.0-py2.7.egg',
'/usr/local/lib/python2.7/dist-packages/Genshi-0.7-py2.7-linux-x86_64.egg',
'/usr/local/lib/python2.7/dist-packages/TracAccountManager-0.4.3-py2.7.egg',
'/usr/lib/python2.7',
'/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7', '
,/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
My PATH and PYTHONPATH (from what is shown in Qgis->Settings->Options are:
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/lib/oracle/11.2/client64/bin
PYTHONPATH: (nix)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140613/80b3f5f2/attachment.html>
